Nick in NM Jacket - Not sure if repairable
Old 02-08-20, 12:08 PM
C
I accidentally nicked the jacket of a piece of NM cable, and Iím not sure if it can be repaired. Itís in a spot that would be very difficult for me to rerun. It does not appear that the conductors are visible. I had contemplated wrapping it in white Scotch 33, but I donít know if that is acceptable. Iíve attached a picture.
Old 02-08-20, 12:15 PM
Z
Received 156 Votes on 139 Posts
No issue, it's probably fine the way it is, but wrapping it with some electrical tape would be a reasonable solution.
Considering you can't even see the insulated wires inside, it's not a nick worth worrying about. If the inside insulation was damaged or you could see copper, it would probably require some more work. I'm sure cables get at least that damaged with normal pulling.
PJmax voted this post useful.
