20 Amp wall oven on 40 Amp breaker
Old 02-16-20, 10:17 AM
N
Hi, I recently took out an old double oven and replaced it with a single oven that states it requires a 20 amp breaker (its a 240v, so a double 20). The wiring is number 8 and the breaker in currently is a 40 amp double. Do I have to switch out the 40 for a 20 and if so can I still use the number 8 wire that is in place?
Old 02-16-20, 10:32 AM
Received 1,324 Votes on 1,224 Posts
Welcome to the forums.
Yes.... you can still use the #8 but you will need to change to a 2P20 breaker to protect the oven.
