Replaced Block Heater Plug
Old 02-21-20, 11:50 AM
W
I just replaced the block heater plug on my 2014 Subaru Crosstrek, and when I went to plug it into power, there was a spark. What might have caused this?
Old 02-21-20, 12:05 PM
Received 295 Votes on 254 Posts
If it didn't trip the breaker I would say normal operation. A block heater draws lots of current so a spark on plug in or plug out would be normal.
Old 02-21-20, 01:20 PM
Received 159 Votes on 146 Posts
Why did you replace it?
If it was because it overheated/melted then there may also be a problem with the extension cord.
Old 02-21-20, 08:59 PM
Received 1,324 Votes on 1,224 Posts
Welcome to the forums from the North.
A good sized block heater...... 400 watts.
My diesel van uses a 1000w block heater.
Typically the plug is exposed to the elements. Between that and a less than stellar extension cord.... a lot of heat gets generated at the plug. My heater creates quite a spark when plugged in. I change the plug every other year as it gets corroded in the elements.
Old 02-22-20, 10:01 AM
CasualJoe's Avatar
Received 97 Votes on 87 Posts
Sounds to me like the block heater was being plugged in under load, a spark would be normal.
Old 02-22-20, 10:51 AM
Since I have never seen a block heater with an on/off switch that was my assumption also.
