3-Way Dimmer Switches
Received 0 Votes
I recently installed a new, dimmable, LED light fixture at the top of our stairwell. The light is way to bright and needs to be dimmed.
Probably a dumb question, but do I need to replace both 3-ways switches (top/bottom of stairwell) with dimmable switches?
Thanks!
Thanks!
Although they do make three way dimmers that work with one regular switch.... they can be a problem to get to operate correctly. I recommend getting a three way dimmer with its companion switch. You can also control the dimming from both ends.
I use the Lutron Maestro line.
