Two separate, yet different circuits in one box
Old 03-04-20, 08:34 PM
D
Would I be NEC and/or NFPA 70 compliant if I put an old 1950's circuit (3 way wire, no available/useful ground 14/2) in a new UL classified plastic switch box, with a new circuit (14/2, plus ground)? Each circuit controls a switch for a light, and the new deep double gang box is rated at 34.6 cu. in. I tried looking for the code, but just couldnt find the detail / answer. My alternative if this is not within code, will be to use separate single boxes on each side of a stud. Thank you.
Old 03-04-20, 09:13 PM
Received 1,167 Votes on 1,082 Posts
Welcome to the forums.
You are allowed to run a separate ground wire to the two wire circuit.
You are keeping the old circuit and the new circuit separate.
You can use the ground from the new circuit to ground the new two gang box and devices.
Old 03-05-20, 04:09 AM
pcboss's Avatar
Received 91 Votes on 78 Posts
There is no issue with multiple circuits in one box.
Old 03-05-20, 11:09 AM
D
Thanks pj.. and pc.. for your timely replies. Guess also having a live circuit in the gang box when only one of the two circuits is turned off is not an exposure. Is it ok to put a tag in the box stating there are two separate circuits, or is it an electricians good process that discounts the need? Thanks again in advance.
Old 03-05-20, 12:32 PM
T
Received 43 Votes on 42 Posts
I have only seen such kind of warnings where there is two or more energy sources; as in, generator, UPS vs street power. Two or more branch circuits in a single box is not unusual.
Old 03-05-20, 02:41 PM
L
Received 83 Votes on 72 Posts
There is no need to put a tag. As long as a qualified person is working on the circuit, he/she should know.
This is very common practice for 2 gang switches controlling 2 different sections and garbage disposal and receptacle sharing same junction box (2gang).
Just be sure not to tie neutral from 2 different circuits together. Ground should be tied together though.
Old 03-06-20, 09:39 PM
D
Yeah, no neutral tie, as they then wouldnt be separate circuits.
Good here then; Thanks again to all...
Old 03-07-20, 09:58 AM
I have put notes on the back side of the device plate.
