Help with GFI receptacle
Old 03-21-20, 08:51 PM
I had my microwave 700 watts plugged into a GFCI outlet in kitchen. Outlet just tripped tonight. It had been working fine. Tried microwave on another GFCI and it worked. GFCI microwave was plugged into will not trip if I plug something else into it like the toaster. Any help would be greatly appreciated!
Old 03-21-20, 09:12 PM
Received 1,351 Votes on 1,249 Posts
Welcome to the forums.
So if you try the microwave back in the original GFI receptacle..... it still trips ?
Old 03-21-20, 09:18 PM
Help with GFCI outlet
It trips as soon as it is plugged in. I tried microwave on a GFCI in another room and it did not trip the GFCI outlet when it was plugged in. I plugged the toaster into the GFCI outlet the microwave tripped and there were no issues. It was working fine all day without issues. I just happened to look over and notice the clock on it wasn't working.
Old 03-21-20, 09:37 PM
Does the microwave have a three prong plug ?
We know the toaster has a two prong plug.
The microwave works fine in a different GFI receptacle.
The toaster works fine in the questionable GFI receptacle.
My thought is problem with ground at the questionable location.
Does each GFI receptacle operate independently or is there another non GFI receptacle connected to the problem GFI location ?
Old 03-21-20, 09:53 PM
Microwave is three prong. I checked ground and it appeared fine. The GFCI outlet that tripped did not affect any other outlets.
Old 03-21-20, 10:09 PM
GFI protection monitors an imbalance between hot and neutral. With a two prong appliance..... the GFI will never trip unless that appliance touches ground like at the sink.
With a microwave and a three prong plug...... the GFI could see a problem between the hot slot and ground. That would indicate a problem within the microwave. However if there was a problem with the microwave it would trip any GFI receptacle it was plugged into.
The next logical step would be to replace the GFI receptacle to eliminate that as a problem.
Old 03-21-20, 11:38 PM
I will do that in the am. I did also plug in a 3 prong power strip and it did not trip. Thank you for all your help.
Old 03-22-20, 01:27 PM
Still not working
. I replaced a GFI in kitchen because microwave kept tripping it. It still trips it. It is a 700 watt microwave oven and was working just fine until last night. I have plugged the microwave into a different GFI in another room and it did not trip it. Any help is greatly appreciated!
THREADS COMBINED
Old 03-22-20, 04:15 PM
Tolyn Ironhand's Avatar
Received 253 Votes on 221 Posts
Try one more GFCI. I suspect there might be something wrong with the microwave. (and the non-tripping GFCI for that matter)
Old 03-22-20, 04:58 PM
I just tried a GFI in the bathroom and the microwave tripped it. Does that mean it is a microwave issue? I can not afford an electrician so much rather due without microwave! Thank you for any and all help!!!!! My location is central Tx area.
Old 03-22-20, 07:56 PM
pcboss's Avatar
Received 105 Votes on 91 Posts
When the issue moves with the appliance you have an appliance issue.
CasualJoe voted this post useful.
Old 03-23-20, 11:33 AM
Keep the replies/topic in one thread to eliminate second guessing.
Old 03-24-20, 03:29 PM
CasualJoe's Avatar
Received 97 Votes on 87 Posts
I'd say so. ..........................
Old 03-24-20, 04:40 PM
The reason I combined the threads was in the first one..... he tried the microwave on a completely different GFI receptacle and it did not trip. Then he tried another GFI and it tripped. If it was a guaranteed microwave problem.... it should trip any GFI receptacle.
