Main Breaker Grounding
Old 03-26-20, 07:53 PM
My breaker/main cutoff is on the opposite end of.my house from my water supply line. The ground wire runs along the natural gas line between the two. Can I run the ground to the outside and connect it to two grounding rods or does an internal main box need to be grounded internally?
Old 03-26-20, 08:13 PM
Received 185 Votes on 164 Posts
It should have both. The main water line if metal should be grounded where it enters the house and you should have ground rods. The rods can anywhere convenient to the main disconnect.
