GFI Problem
Old 03-27-20, 07:46 AM
R
GFI Problem
When I turn on the light in my garage the GFI in the garage trips. However the light does come on. Any ideas on what the problem might be, and what I can do to further research the problem?
Old 03-27-20, 08:14 AM
Received 326 Votes on 281 Posts
The GFCI is miswired.
First thing to do is open the GFCI and see how it is wired. Then determine how the light is wired into the circuit.
Old 03-27-20, 08:38 AM
P
Received 913 Votes on 840 Posts
It sounds like the light is not wired into the load side of the GFCI meaning the light is not GFCI protected.
Old 03-27-20, 10:20 AM
Z
Received 199 Votes on 178 Posts
Has anything changed recently? New lighting fixture or wiring changes?
Old 03-27-20, 01:39 PM
R
This has just started. The light switch has been working fine since we moved in, 6 years ago. Nothing has changed. No new lighting fixtures or wiring changes.Could the light switch or the GFI outlet go bad?
Old 03-27-20, 05:14 PM
CasualJoe's Avatar
Received 111 Votes on 98 Posts
Those are always possibilities. The light and switch really shouldn't be GFCI protected, but it isn't a code violation for them to be. Hard to diagnose with out being there, but my first reaction is that the GFCI is bad. Is it a GFCI breaker or receptacle?
Old 03-27-20, 07:52 PM
Z
Since the light still goes on, the GFI definitely isn't working the way it should be.
If it's a normal incandescent bulb, there's not much to go wrong with it. If it's a CFL or LED, it's possible it's causing some noise on the line that's confusing the GFI. Weird things like that have happened before.
If it's a CFL or LED bulb, I would temporarily replace it with a standard bulb and see if it still happens.
If so, I would probably try replacing the GFI. In either case, it's probably an over-sensitive (old) GFI receptacle that's the root of the problem.
Old 03-28-20, 09:08 AM
R
I have ordered a new GFCI from Amazon, it will be here on Tuesday. I will update after I install it. I will also try replacing the CFL bulb first.
Old 03-28-20, 09:32 AM
R
It was the light bulb. When I went to unscrew it, it broke off at the base. When I put a new one it everything worked. Thanks everyone for your help and suggestions.
