Wiring question: losing my mind or wildly ignorant?
Old 04-04-20, 05:14 PM
E
Cool Wiring question: losing my mind or wildly ignorant?
I have a 10 meter section of cable that is a standard 3 wire cable with three #12 copper wires in it. I've tested this cable disconnected from everything and there are 0 ohms across any of the 3 possible combinations (red-white, red-black, and white-black). I assume then that there is no short in this cable.
I have a wall socket in my house with a hot black wire and a neutral wire. I read 123 volts across these two. So far, everything seems ok.
The first connection I make to any of this is to connect the hot black from the house to the black lead of the 10m three wire cable from above. In essence the only thing I've done is extended the length of the hot lead from the house to the end of the 3 wire cable. That's it...nothing more.
However, I now measure the voltage difference between the white lead from the 10m cable and the white neutral wire from my house and I read 32 volts ?!?! Huh ?!?! There should be no continuity between the white and black wires inside the 10m cable.
I then connect the white wire from the cable to the white neutral from the house - not even a tiny spark. However, I get .1 amps (12.3 watts) being read by my Fluke tester. So, I have 12 watts running through an unconnected circuit. I am beside myself. I know enough to have heard of inductive currents. Is that what this is? 12 watts seems like a lot of power to burn just to extend the length of a cable by 10m. What on earth could be going on. Here is an image of the above description in case the description wasn't clear enough.
Popular Reply
04-04-20, 05:40 PM
joed
joed is offline
Received 190 Votes on 168 Posts
0 ohms is a short. Can we assume you meant zero reading or infinite ohms?
Phantom voltage. It is a normal problem with hi impedance digital meters.
How are you measuring the watts?
Old 04-04-20, 05:37 PM
P
Received 45 Votes on 38 Posts
You are getting false readings. You an analog meter or test light.
EscapedArtist voted this post useful.
Old 04-04-20, 05:40 PM
CasualJoe, EscapedArtist voted this post useful.
Old 04-04-20, 05:44 PM
P
Does your fluke have a low impedance setting?
Old 04-04-20, 08:31 PM
E
Thanks for the responses. Yes I meant infinite resistance...shouldn't have made that mistake.
I'm getting the watts by multiplying the .1 amps by 123 volts. But, I suppose it could be just 3.2 watts because the voltage was just 32 volts. But that doesn't change why I'm seeing any volts at all and especially why I'm seeing current. Does one wire, lying next to another wire that has an AC charge, build up voltage from the simple fact that it is lying next to that charged wire? 32 volts isn't the end of the world, but it seems radical to me...at least I've never witnessed this before.
My meter is a Fluke T5600. It doesn't say high-impedance and has no impedance switch that I can find.
Old 04-04-20, 08:42 PM
E
Hi Pattenp,
I don't have an analog meter. I always liked the digital ones because they are so easy to read but I'm obviously a novice at this. Should I reconsider using digital meters? I've never seen a problem like this!
I do have a non contact voltage detector (came in the kit with the meter). The whole reason I found this issue is that it was blinking weakly on that line with the weak voltage. I thought I had some sort of leakage across the wires, but I doubt that now after testing.
You say, "you are getting false readings". Does that mean a faulty fluke reader, or does that mean an over sensitive reader and I need to get used to seeing voltage like this? I certainly don't like to see any voltage that I'm not expecting
Old 04-04-20, 08:56 PM
pugsl's Avatar
Received 50 Votes on 46 Posts
No meter problem, Means meter to sensitive for household use.
Old 04-04-20, 09:04 PM
E
I have now read a bit on phantom voltage. I only remain confused about the .1 amp current, but I just tested that once and without being really careful, so I will assume for the moment that my problem was indeed phantom voltage. With no spark at all on the 32 volts I witnessed, I have to assume there was not much if any current. Cased closed on a newbie. Thanks for the quick replies!!
Old 04-05-20, 05:35 AM
How are you measuring amps? I think everything is OK. It is just the sensitivity of your meter and how you are using it.
Old 04-06-20, 02:57 PM
E
Hi Joed,
I just quickly stuck the hot wire in the current U of the meter. I glanced at it and saw .1. But the whole thing was jammed up against the wall with other wires nearby and that was not a careful reading. I had assumed, with the voltage, that I would indeed get some current, so I didn't think to measure it carefully and then double check. Now it is all sewed up so I don't want to go in and measure again.
Old 04-06-20, 04:38 PM
Dangerous. If there was any power on that circuit the meter would have acted as a short, tripped the breaker and possibly blown up in your face. Current measurement always has to have a load.
Old 04-16-20, 01:33 PM
E
I might not understand your point, but I was measuring current with a non-invasive meter...a current clamp...one of those U shaped things the just wraps around an insulated wire.
