How to wire this table saw switch
Old 04-06-20, 06:47 PM
P
Hey there I bought this unisaw table saw recently and would like to hook up a single phase motor to this 3 phase magnetic switch that came with the saw. Is it possible to hook it up to this switch and if so how would you go about wiring? thank you
Popular Reply
04-07-20, 07:04 AM
beelzebob
beelzebob is offline
Received 101 Votes on 88 Posts
I doubt you can use the switch directly as it is designed to use 575 VAC 3 phase. Your single phase will need to be near 575 VAC as this is the voltage required by the start solenoid. Secondly, the OL devices won't be usable as the current on single phase (assuming 2 hp motor) will be higher than on 3 phase. You could connect the motor to the start contact output but you lose the motor overcurrent protection.
Old 04-07-20, 07:04 AM
B
CasualJoe, PJmax voted this post useful.
