Outdoor Outlet for Large Plugs
Old 04-10-20, 08:24 AM
Y
I need an outdoor outlet that will accept 2 oversize plugs. Standard weather resistant outlet boxes will not let me plug 2 plugs in (they do not fit). The plugs are for Arlo Cams and the plug ins are about an inch. Are there larger boxes & covers to accept larger plugs?
Old 04-10-20, 08:40 AM
P
Received 125 Votes on 99 Posts
Have you looked at in-use boxes with the large cover?
Old 04-10-20, 08:51 AM
Norm201's Avatar
Received 292 Votes on 262 Posts
Typically an over sized plug is designed so as not to allow another item in a standard duplex outlet. And most weather resistant or weatherproof outlets are standard duplex outlets.
Old 04-10-20, 09:15 AM
P
??? Norm is talking about the outlet size and I was thinking you were asking about the box size. So which is it that's giving you the problem?
Old 04-10-20, 11:07 AM
Received 1,351 Votes on 1,249 Posts
I believe the OP is talking about wall warts for the cameras. Rarely do two fit in a standard receptacle.
I was under the impression that the Arlo cameras were battery operated.
Old 04-10-20, 12:29 PM
P
There is a power adapter for the Arlo cams. So the issue is getting two of the adapters into one duplex socket?
If the adapters don't have a neutral plug in orientation then it looks like they'd fit in the socket end to end, but then the cover box becomes the problem.
Old 04-10-20, 12:51 PM
Norm201's Avatar
I've installed outside cams similar to what you want to do. Since my cam is close to a window I was able to thread the power brick wire between the window screen and the bottom of the window sill. It does not affect the closing of the window.
Old 04-11-20, 06:34 AM
A
Received 23 Votes on 22 Posts
Would a two gang outdoor box with a bubble cover do it? Like this one?
When you install the receptacles in the 2 gang maybe switch them so one faces one way and the other one faces the other way (opposite direction).
Old 04-11-20, 10:47 AM
Tolyn Ironhand's Avatar
Received 253 Votes on 221 Posts
Install a 2 gang box and in-use cover.
Old 04-11-20, 11:55 AM
More than likely if you need to plug both in at the same location.... you will need two boxes, receptacles and covers. I don't think two adapters will fit side by side in a double duplex.
I looked at the adapters they offer.
No dimensions listed and hard to get a feel for the actual side from a picture.
