Wiring Diagram on Motor from China
Old 04-12-20, 06:06 PM
F
I have a motor from China that is currently wired for 110 and I want to change it to 220. The picture shows how it is currently.
Are the schematics left and right for motor direction?
V1=line?
V2=line?
U1=neutral?
Old 04-12-20, 08:50 PM
L
Received 93 Votes on 81 Posts
That wiring diagram only shows how to change direction of the motor.
Are you sure it is setup for 110V and is possible to change? The label only lists 220V.
Old 04-12-20, 08:51 PM
Received 300 Votes on 257 Posts
With 240 volts there is no neutral. You only have two hots or L1 and L2.
U1 is an internal connection related to direction change.
Old 04-13-20, 04:12 PM
Andrew's Avatar
Received 14 Votes on 10 Posts
Also, note that that is a 50Hz motor, not a 60Hz motor. That may or may not be an issue as far a speed is concerned.
Andy
Old 04-14-20, 07:23 AM
B
Received 101 Votes on 88 Posts
Where are you located and how do you know it is wired to operate with 110 vac. In the USA the single phase voltages are 120/240 vac, 60 hz..
Old 04-14-20, 11:22 AM
Received 1,351 Votes on 1,249 Posts
The member is located in Texas.
Old 04-14-20, 04:52 PM
F
Thanks for all the replies,
I bought it wired for 120 and have been running it here in Texas for a year now. It is on a grain mill and the seller sales in either 110 or 220. Can I rewire it to 240?
Old 04-14-20, 05:28 PM
L
It may or may not be possible to rewire. Just not enough information on the motor to determine.
There may be a unused tap on the motor winding, but cannot tell from the picture. You may have to take it to the motor shop.
Old 04-14-20, 05:29 PM
Tolyn Ironhand's Avatar
Received 253 Votes on 221 Posts
Why do you want to rewire it?
