Subpanel
Old 04-16-20, 07:40 PM
A
Subpanel
I had a licensed electrician put a subpanel in my shed that is fed from a subpanel on the back of the house and I have some questions.......he used the red as a neutral as you can see and bonded to the other neutral bar. And the ground wire on the power infeed is actually a black wire that is just stripped all the way to look like a ground wire. The wire used had 3 blacks and a red. Does this look right? Aren't neutrals always white and grounds always green or bare?
And yes, I have 220v in the shed as well.
https://photos.app.goo.gl/tU8T1Em3ewCsVVMZ7
Old 04-16-20, 09:07 PM
pcboss's Avatar
Received 105 Votes on 91 Posts
Your photo doesn't show enough to determine the issues fully.
Old 04-17-20, 12:55 PM
Received 1,351 Votes on 1,249 Posts
Yes.... that is correct.
Red is not allowed by code to be used as neutral..... period.
Green must be used for ground.
Over a certain gauge wire.... it can be remarked with tape.
That wiring is too small to be remarked per code.
The install is safe it's just not code compliant.
Old 04-17-20, 01:02 PM
G
Received 1 Vote on 1 Post
Are ground rods required?
Old 04-17-20, 02:50 PM
If it is a separate building then yes.... a ground rod is required.
Old 04-17-20, 05:15 PM
CasualJoe's Avatar
Received 97 Votes on 87 Posts
There was obviously no permit/inspection on this job.
Old 04-17-20, 06:20 PM
A
As long as it's safe I'm not going to worry about it. But can anyone tell me what the wire is called or referred to? I didn't know wire with 3 blacks and a red was made.
Old 04-17-20, 06:50 PM
P
Received 125 Votes on 99 Posts
That's not a cable. It looks like individual thhn wires and the dude cheaped out using what colors he had on hand.
Old 04-17-20, 08:38 PM
A
Received 48 Votes on 43 Posts
I would check to see what breaker is feeding this panel. If 10 gauge wire it shouldn't be bigger than 30 amps.
Old 04-17-20, 08:41 PM
A
I checked the breaker it's fine. It's a 20 or 30 amp double pole can't remember which.
