New 120v line for gas stove....
Old 04-20-20, 08:26 AM
C
Hey all,
I currently have an electric range, 240v. It is on the fritz and the wife would like to replace it with a gas unit.
When we installed lp, I ran a line to the s stove so that is all set. But the new gas range uses 120v which I never even thought about.
What would be the most efficient way to fix that? Can I adapt the Circuit/wire/outlet that is already run (which is huge)? Or should I pick up a new breaker & line & run a new line? If I run a new line, is there a rule for how close it can be mounted to the 240v receptacle?
Ive run lines before....I ran the 240v line that is there currently, I just want to make sure my plan is good before I proceed.
Old 04-20-20, 08:40 AM
Received 83 Votes on 78 Posts
Why not just tap off of one of the counter outlets?
CasualJoe voted this post useful.
Old 04-20-20, 08:51 AM
C
I can if that is legal. I was under the impression it had to be its own line...
Old 04-20-20, 09:37 AM
Received 300 Votes on 257 Posts
Old 04-20-20, 09:16 PM
L
Received 93 Votes on 81 Posts
120V range doesn't have to be on a dedicated circuit. It can share with 120V appliance receptacles as far as I know.
You can utilize existing cable for 240V as well, but if you have aluminum wire, you cannot just wire nut copper wire to it. You will need Polaris connectors or copper to aluminum split bolt (it has a plate in the middle to separate copper and aluminum)
Old 04-21-20, 10:52 AM
Z
Received 161 Votes on 143 Posts
I don't believe the range receptacle can be tapped from the countertop receptacles (Small Appliance Branch Circuits). It can be tapped from the lighting or really any other circuit.
As Lambition mentioned, you could reuse the old range wiring, but it's often more of a pain than it's worth. Also since that gage wire needs to be adapted on both ends (probably won't fit in the 15/20A breaker).
If possible, I would run a new circuit or tap off a circuit that isn't the kitchen countertop, laundry, or bath circuit.
Old 04-23-20, 07:48 AM
C
I just ran a new 12/2 20a line to the panel, itís been about an hour of extra work but I like having it on itís own circuit. Thanks for the help all!
Old 04-23-20, 01:15 PM
Z
Great! Thanks for letting us know how it turned out.
Old 04-23-20, 06:20 PM
pcboss's Avatar
Received 105 Votes on 91 Posts
The gas stove can be fed from the SABC.
