AC Disconnect for Mini Split Air-conditioning
Received 0 Votes
Hello, I'm planning on installing a mini split condenser unit that requires 240v/30A. I need to run a dedicated line from my breaker to an AC disconnect. I need to know if my plan is correct. I'm planning on using 10/2 Romex and run it to a 30A double pole breaker. Any insight would be greatly appreciated! Thanks!
Welcome to the forums.
Running 10/2 NM-b from a 30A double pole breaker to a disconnect.
The protection is the breaker in the panel. You can use a non-fused disconnect.
All you need is a 30A disconnect but typically the 60A version is easier to find.
A/C disconnect
A/C disconnect
CasualJoe voted this post useful.
