How to free up space in this panel
Received 0 Votes
I need to add a 2 pole 60 amp circuit for a car charger. Any ideas on how to free up 2 spaces in this panel? I can swap the current 2 space 40 amp A/C breaker to a triplex breaker and move 2 circuits there which frees up 1 space. Then I can switch the top 20 amp single space breaker to a tandem single pole breaker to free up a half space. ... but that only frees up 1.5 spaces total and I need 2. Any ideas? Thanks!!!!
There is no room. That panel is already full of tandem breakers.
A new panel or a sub panel and move some of the circuits to the sub panel to get the breaker space for the sub panel is needed.
Welcome to the forums.
Yes.... that is ok. You can leave the ground and neutrals connected where they are
and just extend the hot wiring to the breaker.
can I extend the current circuits with a wire nut splice
Some of the electrical guys may have a good answer why NOT to do this but........
Personally, I'd have someone come in & install a new larger panel. I counted 39 spaces in your current panel but its got to be a 40 space panel. I dont know for sure but I am assuming you can get a 60 space breaker panel?
After research... yes you can:
https://www.homedepot.com/p/Square-D...dalType=drawer
Looks like a meter main so a bit more involved to replace.
Back to original question. To free 1/2 space you could combine circuits. Stove+refrigerator, washer+dryer, GD+dishwasher, attic+BR lights. Other option to put panel in garage with garage, garage lights, and charger but finding circuits might be difficult.
