Switch Plate over Metal Raised Mud Ring
Old 05-03-20, 07:22 PM
B
Received 1 Vote on 1 Post
Would it be considered out of code to install a switch plate cover to a raised mud ring if the junction box is exposed?
I've attached some photos of what I'm describing:
Basically I have a 4 11/16" square junction box - on top of that I've attached a mud ring to on which I'd like to install a double switch & a double receptacle. I would then like to cover those with the double switch plate. The area where this switch/receptacle would be is an unfinished attic so there is no sheet rock just wood studs. Can a plastic switch plate sit flush on a raised mud ring or must it be flush with the junction box? See side view photo
Before anyone asks the reason I'd like to use the 4 11/16" junction box rather then the 4" square is I like more room in my junction boxes whenever possible
Old 05-03-20, 07:33 PM
B
Apparently it won't allow me to upload my phots because I've exceeded my quota. Does anyone know how to delete old attachments so I can repost pictures?
Old 05-03-20, 07:38 PM
XSleeper's Avatar
Received 670 Votes on 620 Posts
Use a photo hosting website and post links instead.
Old 05-03-20, 07:52 PM
Received 1,112 Votes on 1,032 Posts
Using a 4 11/16" junction box is a good idea for extra wiring room.
It is perfectly acceptable to use a finish plate on a mud ring with a surface mounted box.
How-to-insert-pictures.
Old 05-05-20, 09:07 AM
CasualJoe's Avatar
Received 86 Votes on 76 Posts
The best way is to forget the mud ring and just use a 4 11/16" raised cover for two duplex receptacles.
https://www.walmart.com/ip/4-11-16-S...EaAvjREALw_wcB
Old 05-05-20, 10:02 AM
B
Didnít know they made one to directly fit over it
Old 05-05-20, 10:16 AM
XSleeper's Avatar
As you can see, to use that type of cover the box needs to have the studs offset on all 4 sides. So it depends on the box you have.
