Help wiring Honeywell Thermostat for Electric heat
Old 05-10-20, 01:28 PM
L
Hi all-
I purchased a Honeywell thermostat for electric baseboard unit. The current thermostat is wired in the following pic:
The new thermostat and wiring diagram is as follows:
I’m not sure how to wire. I assume L1 is for the black load? Should I be connecting L2 and T2 similar to the current thermostat? Thoughts?
Old 05-10-20, 02:12 PM
Tolyn Ironhand's Avatar
Received 252 Votes on 220 Posts
Yes. If you wire it the same as the old one it should work. You are not using L2 and T2 which is why they are connected together.
lpaul626 voted this post useful.
Old 05-10-20, 03:00 PM
Received 1,324 Votes on 1,224 Posts
You need to nothing to the L2/T2 wires but you can wirenut them like before.
