Old panel to new panel to wire trough via 2" PVC
Received 0 Votes
Code compliance question; can I do this in my basement?
SEE ATTACHED PICTORIAL
- Add additional basement breaker panel alongside my exiting one. (No more breaker room on the existing panel.)
- Jump old panel to new panel with what ga wire? Old panel: 100 amp. New panel already has 100 amp mains breaker. Breaker size on old panel?
- Build 2" PVC out of new panel to a rafter mounted 6" x 6" x 36" wiring trough. Why? There's no room on right side of new panel for easy new Romex circuits installation.
- Run bare copper ground (4 or 6 ga?) from new panel to ground bus terminal strip in wire trough via the 2" PVC. Terminate all grounds in trough to ground bus.
- Run all new circuits from wire trough to new panel through the 2" PVC using 12 ga. wire (black/white) pairs.
I generally always try to avoid creating a Rube Goldberg.
Received 0 Votes
The new panel is already mounted next to the old panel with a temp jum from the old to the new.
The wire trough was installed some time ago.
The current installation is a Rube Goldberg. (Rube was well intentioned, but his work could kill you. You've been there.)
I need to finish up this project -the right way.
I don't want an inspector to say, rip this out before I sell my house.
I just want to meet/exceed Code.
I also do VERY neat work.
Many thanks!
Many thanks!
If the 2" conduit is more than 24" then you have to take derating into account and then you are pretty much limited to 9 current-carrying conductors. If it is less than 24" it is considered a nipple and you can fill the pipe to 60%.
Breaker size in the main panel? It depends on what size wire you want to use or how many amps you want available to the sub-panel. I would recommend three #6 wires, one #10 ground, and a 60 amp breaker.
Ground wire to the gutter will depend on the largest conductor in the pipe. If it is #12 then you only need to use a #12 for the ground.
the derate issue.might kill the wire trough idea. I was hoping to accommodate more circuits in the 2".
It's typical to solve your problem with separate NM-B cables from the panel to a junction box in the ceiling (accessible), then out to the circuits. It happens when the cables aren't long enough.
It could be a couple double-gang plastic new work boxes, a couple 4x4 metal boxes, or a larger 6x6 or 8x8 box if you'd rather. All are rather usual to see in a setup like this.
Due to the derating requirements, making it look all neat with conduit and trough isn't usually done in residential settings.
