Limited Number of Knock-Outs on Panel
Old 05-17-20, 11:06 AM
B
My breaker panel has a limited number of knock-outs on the right-hand side.
Can I use a larger connector for 4 new NM circuits through a bigger knock-out?
Old 05-17-20, 11:23 AM
Received 1,348 Votes on 1,246 Posts
A connector is designed for a certain amount of cables.
You can't put more cables in a larger connector just because they can fit.
In your application you can use twin cable connectors. Two cables in one KO.
Duplex connectors
Old 05-17-20, 12:31 PM
Tolyn Ironhand's Avatar
Received 253 Votes on 221 Posts
You can also drill your own 1/2" KO's using a hole saw.
I recomend a carbide hole saw like this: https://www.amazon.com/EZARC-Carbide...s%2C189&sr=8-2
Old 05-17-20, 12:34 PM
Good point Tolyn.
If you do decide to drill your own holes...... do that first and save existing ko's or a few for future wiring. It can be hard to drill holes once cables are in the panel.
Old 05-17-20, 02:52 PM
Geochurchi's Avatar
Received 88 Votes on 83 Posts
Hi, these may be a good choice, not need to mess with locknuts, also good for 2 cables.
https://www.homedepot.com/p/3-8-in-N...7515/100197570
Geo
Old 05-17-20, 05:03 PM
The connectors that Geo posted are my least favorite connectors as they are VERY difficult to remove. These are my go to: https://www.homedepot.com/p/Arlingto...-100/202245823 They will also take 2 cables each and also come in 3/4' if needed.
Old 05-18-20, 06:28 AM
B
Received 101 Votes on 88 Posts
Other options for making holes in the panel are step drills and hole punches. Hole punches create the least amount of metal chips requiring cleanup.
Old 05-18-20, 08:49 AM
L
Received 93 Votes on 81 Posts
A standard 3/8" NM connectors (aka Romex connectors) can take 2 NM cables. (up to 12 AWG)
The one PJmax suggested is required if using AC or MC cables.
Plastic ones works too, but I like metal ones better for easier removal later.
Old 05-18-20, 09:06 AM
T
Received 47 Votes on 46 Posts
Greenlee hole punches work great, with low mess. Iím done using mine. hint..hint.
Old 05-18-20, 07:08 PM
pcboss's Avatar
Received 105 Votes on 91 Posts
I agree about the connectors linked by Geo. Absolutely one of the least user friendly connectors made.
