Inverter and mains (shore power) with common ground
Old 05-17-20, 03:11 PM
B
I have a small trailer with shore power (120v ac) and an onboard inverter (12v dc to 120v ac). I have a manual transfer switch between the two so that only one can be feeding the trailer at a time. The transfer switch only switches the hot and neutral leads. Is it okay for the two grounds to be tied together (bus bar)?
Thanks!
Bob
Old 05-18-20, 07:14 AM
A
Received 110 Votes on 102 Posts
Yes you may tie the ground wires (equipment grounding conductors) together.
Ground wires are all tied (bonded) together wherever they come together -- in junction boxes, etc.also.
