Connecting a high bay light, it's a 250w HPS.
Old 05-21-20, 01:21 AM
How can I connect a 250w HPS to a 120 . Trying to connect it to a extension cord.
Old 05-21-20, 04:15 AM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
Hi, is the fixture rated for 120 VAC?
Geo
Old 05-21-20, 04:41 AM
B
Received 181 Votes on 161 Posts
All HPS lamps require a ballast. Some lamps have the ballast built in. Check the model # of your bulb with the manufacturer's website to see if you need a ballast for the lamp. Match the ballast input voltage with that of the outlet the extension cord is connected to. If the lamp has a built in ballast, match the bulb manufacturer recommended input voltage to an outlet with the same voltage.
