panel cover spring loaded
Old 05-26-20, 03:46 AM
What is the function of the spring loaded inner portion of a panel cover?
Old 05-26-20, 04:31 AM
B
Received 182 Votes on 162 Posts
Would help if you provide a manufacturer and model.
Old 05-26-20, 04:50 AM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
Hi, is it a flush mount cover? if so it helps to mount the cover flush.
Geo
Old 05-26-20, 09:27 AM
like an everyday residential square d cover...the ones I am familar with all have the spring mounted center portion that rest over the breaker slots.
I thought the spring loaded feature was to give pressure to the breakers so they dont pop out.
Old 05-26-20, 10:15 AM
CasualJoe's Avatar
Received 164 Votes on 147 Posts
No, there is no danger of any Square D breaker popping out. That feature is to assist the cover to fit the breakers properly especially in flush installations when the panel box may be set into the wall just a little too far. Earlier QO series loadcenters had adjustment screws to adjust the panel interior out to fit the cover when necessary. Square D has cheapened their products considerably over the years since being acquired by Schneider and the springs are probably just a way they could cut their cost.
