Center mount a single duplex outlet in a 2 gang box
Hello - I used this 2 gang box in a project. I only need a single outlet in it; I used the 2 gang box because it also serves as a junction box and a single gang box would have been too small. I planned to center mount the outlet, but discovered there aren't mounting holes available in the center. The cover I have doesn't allow a single outlet and a blank, but does allow for a center mounted outlet. I can't find an adapter plate to allow center mounting (like this box has), is there a term I should use to find one? I know I oould just buy and install a second outlet too, but the box would then be barely large enough by code.
Thanks!
-Eric
Thanks!
-Eric
Mulberry has a blank/duplex receptacle or blank/GFI two gang weatherproof cover
but it's not an in-use type cover which is required by code for outside receptacles.
Two gang covers on page 17..... Mulberry weatherproof (pdf)
Thanks for the suggestion as always.
In case anyone else tries to do the same thing, I ended up finding a solution to center mount. I used a flat mud ring, which mounted to the box and recessed just a bit into it so that it didn't affect the seal of the in-use cover. I think/hope that is code compliant. I'll post here if the inspector objects.
