Duct seal in conduit ends?
I am running electrical though the side of my house using metal conduit, down through an LB. I assume silicone or some sort of high-quality caulk should be used to seal the pipe to the siding. However, I've been wondering about the wires inside the conduit - air exchange and potential source for bugs (very unlikely) or moisture.
I've seen a product called duct seal - a grey putty-like substance. Is that required or optional? Would adding it to plug the conduit on both ends be a code violation?
Top Answer
06-01-20, 07:17 AM
Duct seal is the correct product. It is specifically designed to not affect the wire insulation.
I don't know if it is REQUIRED, but it won't hurt to use it.
