Old work/retrofit electrical metal boxes
Old 06-01-20, 09:00 AM
D
Received 1 Vote on 1 Post
Just wondering what products people use to retrofit electrical outlets (metal - conduit)
I have used this product a coupe of tiems:
https://www.amazon.com/Hubbell-Raco-.../dp/B000BQMERA
Not bad, but not 100% happy. Good for no stud situations, but requires a rather large cutout, especially around the clamp screws. Also, while box has knockouts ll around. Effectively can only used on rear.
Other option is Madison clip:
https://www.grainger.com/product/RAC...tch-Box-30EJ95
Never used it.
Also used regular box when stud was an option. Screw from inside the box into stud. A bit fidly to get screw in. Ends up being at an angle.
Old 06-01-20, 09:45 AM
Z
Received 84 Votes on 79 Posts
I use the largest metal box available that will fit, and madison bars to secure it when trying to reduce drywall work. But if needed, I have no issue with making a larger hole and using a new-work box with brackets and doing some drywall/plaster repair work afterward. Of course depends how much of the room/house is being redone.
Doesn't help you with conduit, but I've had good luck with Arlington screw-in remodel boxes too:
https://www.gordonelectricsupply.com...ce-Box/5978716
Old 06-01-20, 10:00 AM
A
Received 34 Votes on 30 Posts
Most of the Madison Clips are too short for anything but the thinnest drywall. Instead I use the battleship version - https://www.homedepot.com/p/Steel-Ci...-25R/202596361
Old 06-01-20, 10:07 AM
D
How stable is a box mounted with clips? Also, using a single gang box, is there enough clearance for a receptacle such GFCI?
@Zorfdt I am jealous about all the handy products that are available in the non-metal market....
Old 06-01-20, 02:29 PM
A
Boxes are plenty stable using clips. Curl then ends then use pliers to crimp gets them out of the way and gives plenty of room for GFCIs. No tape needed.
Old 06-01-20, 05:06 PM
Tolyn Ironhand's Avatar
Received 155 Votes on 139 Posts
These work well with F straps: https://www.homedepot.com/p/3-in-x-2...8500/100548372
I have likely installed 1000+ of them. They also make a 3 1/2" deep version for use with GFCI devices
Old 06-02-20, 08:36 AM
Geochurchi's Avatar
Received 43 Votes on 41 Posts
Hi, what are you trying to install, What kind of wiring method ?
Geo
Old 06-02-20, 10:04 AM
Received 850 Votes on 796 Posts
The cut-in gems that Tolyn showed are like the staple of our industry. You definitely want the deep one for a GFI receptacle. The bars must be installed perfectly flat when folded into the box. Most GFI receptacles use recessed side screws to they don't hit the box.
Working with conduit requires a lot of patience when doing old work.
