Is this product code compliant?
https://www.hubbell.com/raco/en/Prod.../405/p/1670208
If you use 14/2 NMB you need 6 cubic inches.
This box is 6.5 cubic inches.
BUT with the internal clamp you lose 2 cubic inches according to code.
How much space is between the pipe and the face of the stud? If you are running a single cable into the box many times a shallow pan box works well. https://www.homedepot.com/p/4-in-Dra...8293/100574367
I have also recently found a pancake box that is for remodeling: https://www.menards.com/main/electri...6260502045.htm but has a slightly larger flange that bay not be hidden behind some smaller sconces.
Also, the canopy of the light fixture will accommodate some of the wiring.
