How to wire old blower motor
Old 06-06-20, 08:32 AM
O
I have an old blower motor that came out of a old sears air purifier. I would like to build a simple housing for it and make a shop fan out of it. Is there a way I could easily wire this up to a standard plug. Thanks for any help you can give.
Old 06-06-20, 08:54 AM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
Hi, any wiring Dia.? look on the air purifier, you will need an Ohm meter to identify the wires if there is no Dia.
Geo
Old 06-06-20, 09:30 AM
O
No wiring diagram so I'm a little lost on where to go from here.
Old 06-06-20, 07:05 PM
Received 2,955 Votes on 2,666 Posts
That's going to be a difficult motor to wire for straight 120v. It looks like it needs a capacitor too.
I went to HHE but could not find any info on that motor.
Old 06-07-20, 10:23 AM
O
Yeah. Ive looked all over and couldn't find anything either. Thanks for the help.
Old 06-07-20, 10:25 AM
Try posting the full model number for the purifier if you still have it.
It will look like xxx.xxxxxxxx
Old 06-07-20, 12:58 PM
O
I no longer have it but this looks like it. https://c.searspartsdirect.com/mmh/l...M/L0805047.pdf
Old 06-07-20, 01:30 PM
L
Received 170 Votes on 146 Posts
Without circuit diagram or reverse engineering control board, it will be very difficult to figure out how to wire the motor.
It probably is multi speed and probably will require capacitors.
Some motor experts probably can open the motor and figure out by looking how windings are connected. You are really better off just buying a fan or motor.
Old 06-07-20, 03:40 PM
I tried to locate the control board but it's been long gone.
