running exposed NM cable in finished garage
Old 06-07-20, 02:08 PM
Received 1 Vote on 1 Post
I would like to install a new circuit in my garage with finished walls and ceiling, the ceiling height is over 8 feet. Is it permissible to run exposed NM at the top of the wall into a junction box then down the wall in conduit for the outlet?
Thanks
Jack P.
Old 06-07-20, 05:02 PM
pcboss's Avatar
Received 148 Votes on 131 Posts
As long as not subject to physical damage you should be good using NEC rules. Local rules may differ.
Old 06-08-20, 02:08 PM
Thanks, I will check with the building inspector.
Old 06-08-20, 06:00 PM
Tolyn Ironhand's Avatar
Received 597 Votes on 512 Posts
For a cleaner look, I would recommend using conduit for all exposed runs. If you do, use individual wires like THHN.
