240v reading
240v reading
does anyone know why I have 240v reading after the meter but not at the bus bars I checked line 1 and line 2 they both read 120 but not 240 inside the panel
They read 120 volts to ground because you have a two-pole breaker that is on. You are reading through a 240v load like a water heater. If you turn off all the two-pole branch circuit breakers you will find out you have one leg that is not hot.
Not sure what you re reading but here is how it works.
Basically you have two 120 volt supplies when measured to Neutral.
So L1 to Neutral = 120 volts and L2 to Neutral = 120 volts.
But the two supplies are 180 degrees out of phase.
So when L1 is at -120 volts, L2 is at +120 volts.
Therefore L1 to L2 = 240 volts
