Understanding Amps
Old 06-30-20, 12:43 PM
D
Understanding Amps
Doing some improvements and wanted to understand basics about electrical
Question :
What happens if I plug a 6 amp device/appliance into a 15 amps socket ( basically a higher amp socket) ?
will it cause any damage to the socket or device ? as in will the 6 amp device pull in more electrical current and burn off ?
I understand Amps is the measure of how much current can flow through a terminal like a water tap/faucet
Old 06-30-20, 01:46 PM
Tolyn Ironhand's Avatar
Received 154 Votes on 138 Posts
That is correct. Amps is a measurement of the flow of electrons through a conductor.
Nothing. It draws 6 amps. 15 amps is the maximum amount of current that is allowed to flow in the circuit. This is limited by an overcurrent device (fuse or circuit breaker) The overcurrent device is directly sized but the wire size in the circuit and some other factors.
No. An electrical device or "load" will only draw the current it is designed to. A 6 amp device will only draw 6 amps of current regardless of the amp rating of a circuit.
