LED Pendant. Breaker trips when turned on.
Old 07-01-20, 04:14 PM
R
Hi! I bought a LED Pendant that's 12V. it came with a 120v to 12v transformer. Every time I turn on the light, the breaker trips. I tried another transformer, same thing happens.
The first picture is the LED driver used.
The second picture is the LED pendant wires that connect to the LED driver.
Old 07-01-20, 04:38 PM
Received 16 Votes on 16 Posts
Have you tried it with the power supply connected to AC power but the light not connected to it? If yes it sounds like a problem with the switch (possibly a mis-wired switch loop) or other circuit problems
Old 07-01-20, 05:53 PM
P
Received 58 Votes on 47 Posts
You are hooking brown to hot and blue to neutral for the 120V input, right?
Old 07-01-20, 06:03 PM
R
CircuitBreaker Yes, it also tripped.
@pattenp Yes.
Old 07-02-20, 04:13 AM
P
Is the circuit breaker a standard breaker or is it a gfci or afci?
Is this replacing an existing light fixture?
Old 07-02-20, 06:07 AM
R
pattenp
It's AFCI. It's replacing a regular light bulb that's working fine.
Old 07-02-20, 07:45 AM
P
AFCI.... there's the possible problem. Do you have a non AFCI circuit to test the led light from.
A brief search reveals that some led transformers don't play well with AFCI.
