switched GFCI outlet
Old 07-27-20, 08:12 PM
1
can a GFCI outlet be switched? or if you have a GFCI outlet at the start of a run can you add another non-GFCI outlet to it, the end of the run, and have it switched (half-hot) like for a garbage disposal?
Old 07-28-20, 05:41 AM
Geochurchi's Avatar
Received 88 Votes on 83 Posts
Hi, I donít know of any reason you canít switch a GFCI, if you add another receptacle to the load side of a GFCI it must be labeled as GFCI protected.
what are you trying to accomplish?
Geo
