Soldering - is galvanic corrosion a concern here?
Old 07-29-20, 10:16 AM
C
Received 5 Votes on 5 Posts
I want to ground this ethernet surge protector. The protector's wire is fairly short. To reach the grounding line that runs from my main panel to my plumbing, I was thinking I'd solder a piece of 12g copper wire to the spade connector on the surge protector. I'm not sure what material the spade connector is made of and was wondering if galvanic corrosion would be a concern?
Popular Reply
07-30-20, 05:16 PM
Tolyn Ironhand's Avatar
Tolyn Ironhand
Tolyn Ironhand is offline
Received 175 Votes on 157 Posts
so you are saying if the surge is big enough that the solder can heat up and melt thus breaking the path to ground?
Exactly. It is not only on ground wires, it applies to all wires. If there is a short circuit that can heat up wire enough to melt the solder and make the connection fail.
Old 07-29-20, 11:09 AM
P
Received 534 Votes on 491 Posts
Your spade connector is likely plated copper so it should solder well to the copper grounding wire. Or, you can cut off the connector and solder copper wire to copper wire.
cartman voted this post useful.
Old 07-29-20, 11:23 AM
Marq1's Avatar
Received 320 Votes on 300 Posts
Galvanic corrosion requires dissimilar materials (the more difference the more corrosion) and an electrolyte, typ water or very high humidity!
Old 07-29-20, 02:20 PM
Received 212 Votes on 188 Posts
You don't have to ground it to the line from the panel to the water line. You can ground it to any point on the electrical system ground.
Old 07-29-20, 02:34 PM
C
Yeah, I know. But since the ethernet cable enters the house close to the panel, might as well ground here and provide a very short path to ground, especially since the whole point is to minimize damage from lightning induced surge.
Old 07-29-20, 07:18 PM
Received 938 Votes on 875 Posts
Slightly off topic......
Grounding or bonding the Ethernet cable isn't really effective.
You want to ground or bond the source of the Ethernet..... usually the cable modem (or whatever you have) in which case it's more important to make sure the cable is grounded.
Old 07-30-20, 08:28 AM
T
Received 32 Votes on 31 Posts
I would not solder to the wrong side of a forked terminal. this is a job for a crimp butt connector.
I have done some EMC work with Ethernet copper. The jacks contain a small transformer that kills CM surge and noise. I do no special treatment for short runs of copper to about 30'. If its a very noisy environment, then go with a shielded system. For very long runs, go with optical. Many copper to fiber boxes out there for 802.3
Old 07-30-20, 03:26 PM
If there is a surge there is a possibility that the solder will fail. This is the exact reason why soldering splices are not allowed by the NEC. You are better off using a mechanical connector such as a split bolt, wire nut, or butt splice.
Old 07-30-20, 04:14 PM
Received 17 Votes on 17 Posts
@ Tolyn Ironhand:
I always wondered what was NEC's reason for no soldered connections allowed so you are saying if the surge is big enough that the solder can heat up and melt thus breaking the path to ground?
I do remember (Way before my time though) in the Knob & Tube days those connections were soldered and taped into a big bunch with friction tape.
Old 07-30-20, 05:16 PM
cartman, CircuitBreaker voted this post useful.
Old 07-30-20, 05:48 PM
T
UL has a similar issue with soldered ground wires. If a device catches fire, they want the ground connection to stay intact. Thus, no soldered ground wires even inside Class 1 devices.
Old 07-30-20, 06:43 PM
C
Thanks. Definitely unaware of that.
I had cut off the spade connector and soldered the device's copper wire to my 12g copper wire. But I'll snip off that wire and join the wires using a wire nut instead.
Old 07-31-20, 11:58 AM
D
Received 21 Votes on 21 Posts
When replacing breakers on old crowded panel with GFI and Arc-Fault breakers I needed to extend some of the white ground wires.
First spliced wires with crimped connectors, then soldered crimp finally covered area with white shrink wrap tubing.
Splice is more reliable than just crimping and less likely to deteriorate through corrosion or whatever. Connection barely noticeably. Positioned splice wires behind others in panel so are not visible.
As a salt water boater have long crimped then soldered electrical connections.
