Replacement cable for generator
Old 08-10-20, 06:33 AM
N
Hi. I have a Generac XG8000E and what appears to be a 30A 125/250V cable (pics below). I believe it's 10' and I want to get a longer one (maybe 25' or so).
In any case, is this the proper replacement; https://www.amazon.com/NEMA-L14-30-G...00H20CTZU?th=1 or do you recommend something different/better?
Thank you!
Old 08-10-20, 07:00 AM
Received 236 Votes on 207 Posts
That is the correct cable.
Old 08-10-20, 07:10 AM
N
Thank you. Is this also correct: https://www.amazon.com/Champion-250-.../dp/B076HQ2THC looks similar (many more reviews though), but the L14 info is a bit different.
Old 08-10-20, 10:27 AM
Z
Received 102 Votes on 95 Posts
As long as you get a 10ga cable with L14-30 plug/receptacle, you're good. The Amazon link you provided looks good.
(There's also an L14-20 plug/receptacle that you don't want)
Old 08-10-20, 11:13 AM
The second one is good also. it has L14-30P(plug) and L14-30R(receptacle).
As long as the cord has a L14-30P and and L14-30R it will work.
Old 08-10-20, 12:27 PM
R
Received 4 Votes on 4 Posts
I'm going thru the same process and what you pictured was the same cord (SJOOW) the pro's here suggested I use to go from the generator to the inlet (receptacle).
Since you already have the ends which are about $15 bucks each, would the most efficient way be to just buy the length of SJOOW needed?
Old 08-10-20, 07:32 PM
Received 1,021 Votes on 947 Posts
10/4 cable is available bulk at the home improvement stores. Depot has it for $2 a foot.
10/4 rubber cable by the foot
Old 08-10-20, 09:59 PM
Cheaper to buy he one linked. Same price as cable and you get the ends.
