30 amp RV Box/Outlet questions
Received 0 Votes
I'm going to install an RV box near the breaker panel.
30 amp single pole breaker
30 amp RV box and outlet.
Total wire run of less than 6 feet, so I plan to run 10 ga wire. Want to use 1/2 inch conduit that I have on hand.
Is there any reason I can't run 3 #10 solid wires (blk, wht, bare) in 1/2 inch conduit? Like code, for example.
Second, I want to use a GFI breaker. The RV I'll be plugging in has GFI on the 15 amp plub outlets.
Will having two GFI breakers on the same circuit cause any problem?
Thanks
Thanks
Welcome to the forums.
Yes..... you could get false tripping.
Outside.... in flex..... the ground needs to be insulated and green.
1/2" conduit is ok.
1/2" conduit is ok.
