In ProcessAdSlots.php line 39: Trying to access array offset on value of type null
Reload this Page >
Bathroom light doesnít always turn on and sometimes flickers
Old 08-27-20, 08:26 AM
D
Received 2 Votes on 2 Posts
House is 20 years old I am original owner. I replaced bathroom light about 10 years ago and Iím using 3 compact fluorescent bulbs instead of the incandescent.
a few days ago I noticed the light didnít go on when I flipped the switch, and sometimes flickered for a second. Eventually it would turn on, maybe after 4 or 5 tries. It would then stay on until I shut it off.
yesterday I removed the cover plate and checked switch connections. Seemed tight, however, electrician used the push-in connector. I was once told not to use those because they are more likely to fail as opposed using the screws.
i could just replace the switch and see if that works, or re connect using screws. Could possibly be the fixture but i want to rule out the easier fixed first.
Old 08-27-20, 08:52 AM
B
Received 101 Votes on 88 Posts
Move the wires from the push-in connections to the screw connections at the switch and light as a first attempt at correcting.
Old 09-06-20, 04:32 PM
I bet its those florescent bulbs, I would try an incandescent or LED and see if it starts instantly- if it does, you know whats wrong.
Old 09-07-20, 07:20 AM
G
Gen
Gen is offline
Received 3 Votes on 2 Posts
You have either IMHO...
--Bad switch device.
--Bad wire connections ON the switch.
--Other bad wire connections inside the switch box.
--Bad connections to the light or within the light junction box
--Something feeding the switch, such as a GFCI outlet, has bad connections.
There are other possibilities also, but likely problem is at the switch.
Old 10-26-20, 04:28 PM
K
Sometimes reverse polarity can cause problems
Old 10-26-20, 04:34 PM
Tolyn Ironhand's Avatar
Received 253 Votes on 221 Posts
Doubtful. It is alternating current (AC)
Old 10-28-20, 03:23 PM
CasualJoe's Avatar
Received 97 Votes on 87 Posts
Replace the switch, it's 20 years old and frequently used in a bathroom. A frequently used 15 amp residential switch will only last 20 to 25 years.
Old 10-28-20, 03:37 PM
D
Thought I posted update. I replaced switch and problem solved. Thanks!
CasualJoe voted this post useful.
