6 outlets to wire nut
Old 08-27-20, 06:52 PM
Q
Received 1 Vote on 1 Post
I have a triple gang box with the following:
1 source
1 single pole switch to 1 outside light
1 single pole dimmer to lights
1 three way to lights in another box
3 circuit continuations to other boxes
So, I need to wire nut 7 black wires together.
Is there a better way? I have seen some electricians take a long black wire and instead of pig tailing, they strip in the middle of the length and then go to the next switch and strip a bit then to the final switch all with the same length of wire.
Could I also nut 4 together and then pigtail to another nut with 3 just for the switches? Like a double pigtail...sort of.
Old 08-27-20, 07:24 PM
L
Received 92 Votes on 80 Posts
This is what I would do..
However,
This probably will over fill the box. It would be best to daisy chain the circuit instead of bring all into a single box.
Yes you could do that. But that will probably take up more space than putting 6 wires under a large wire nut.
Old 08-27-20, 08:02 PM
Tolyn Ironhand's Avatar
Received 253 Votes on 221 Posts
This is how I do it. It can be a bit of a challenge to get it right. I use about 4" of wire loop between devices.
You could also use 2 - 4 port push-in connectors. They will take a lot less room than a big wirenut.
