30 amp RV Box/outlet questions
ok I am adding a 30 amp power box to my house to plug in my RV when friends/family come to stay. the question is I am going to run a new line from the breaker box to the newly installed 30 amp panel outside (with its own 30 amp breaker) what size should the breaker inside be?
ok I am adding a 30 amp power box to my house to plug in my RV when friends/family come to stay. the question is I am going to run a new line from the breaker box to the newlyTutuapp 9apps Showbox installed 30 amp panel outside (with its own 30 amp breaker) what size should the breaker inside be?
Hi, what size cable are you running?
Geo
Hi , the size is 30
thanks
Geo
Hi , the size is 30
thanks
In order to post pictures..... How-to-insert-pictures.
10-2 NM-b with ground and a single pole 30A breaker.
