Reload this Page >
Replaced my old honeywell with new Honeywell Thermostat 6360
Old 08-29-20, 08:27 PM
D
Replaced my Old Honeywell with a new honeywell; but the system is blowing hot air. Please help.
Old 08-29-20, 08:53 PM
A
Received 48 Votes on 43 Posts
I think you have the orange and white wires swapped. You need to follow the "heat pump" letters.
Old 08-29-20, 09:01 PM
D
Ok. I will try it.. I believe i started Wiring it that way, but I will let you know. The orange was the "White" on the old system and the White was on W2.
Old 08-29-20, 09:17 PM
Received 1,324 Votes on 1,224 Posts
Orange needs to be on O/B.
White needs to be on AUX/W.
That doesn't look like a straight 6360 base. Can't see heatpump lettering but it looks like there are two AUX terminals..... AUX/W and AUX/W2
Old 08-29-20, 09:26 PM
D
I changed it like you mentioned Pete. I will let it run for a while and see.
Old 08-29-20, 09:34 PM
D
I also notice the initial installer had a wire going in the RC. I don't know why they did that.
Old 08-29-20, 09:38 PM
That thermostat is internally connecting the R to Rc. That's what that switch is for.
Since I couldn't see the wiring on the old thermostat.....we are assuming this is a heat pump.
Did you program the new stat for heat pump operation with backup electric heat ?
Old 08-29-20, 09:44 PM
D
No . Did not program it. Would be glad to know how to.
Thanks
Old 08-29-20, 10:50 PM
1) Press and hold [Menu] and [+] buttons for approximately 5 seconds to enter advanced menu.
2) Press [Select] to enter System Setup.
3) Press[ Select] to cycle through System Setup numbers.
These two must be changed.
After you change the following two.... you can step thru to the end and press [done.]
system number 200 - heating system type gets changed to 2 - heat pump.
system number 205 - heating equipment type gets changed to 7 - air to air heat pump.
