Switch power rating
Old 09-18-20, 12:13 PM
Received 3 Upvotes on 3 Posts
Switch power rating
I have a toggle switch that is rated for 250V/10A. If I use this switch on a 110V circuit, would the max rating remain at 10A or be something else?
Old 09-18-20, 12:24 PM
P
Received 1,756 Upvotes on 1,569 Posts
Is the switch rated for AC or DC? Sometimes the amperage capacity for AC is Different than DC.
Old 09-18-20, 12:30 PM
Sorry my bad. I should have mentioned that it is AC.
Old 09-18-20, 01:22 PM
Received 3,407 Upvotes on 3,057 Posts
250V/10A
The switch is rated at 10amps.... period.
250v is the maximum voltage that should be run thru it.
Old 09-19-20, 07:03 AM
B
Received 233 Upvotes on 206 Posts
The stated voltage and current are maximum values. If switch ratings are AC, the values are RMS, not peak.
