Junction box enclosed in the wall
Old 10-15-20, 03:37 PM
Had a carpenter over today (redoing kitchen) and he said there's now a way to enclose a junction box behind a wall. I want to close off some outlets behind cabinets and I said we'll have to cut an access panel in the cabinet where the outlets are. He said there's now a way to bury wires. I didn't believe him...he's not an electrician.
Is there any way, shape or form this is possible? Thanks.
Old 10-15-20, 04:05 PM
Received 247 Votes on 217 Posts
You are correct. He is wrong.
pcboss's Avatar
Received 87 Votes on 74 Posts
The junction needs to remain accessible. Do not let them bury a splice.
Old 10-15-20, 04:10 PM
Received 1,110 Votes on 1,030 Posts
They do have splice kits available for in wall splicing but they are not reliable.
That's probably what your carpenter was referring to.
Old 10-15-20, 05:23 PM
C
Received 13 Votes on 11 Posts
@PJmax, are you referring to these?
These are permitted by the NEC, correct?
Old 10-15-20, 06:18 PM
L
Received 7 Votes on 6 Posts
"These are permitted by the NEC, correct?"
When concealed, they are allowed for repairs only.
cartman voted this post useful.
Old 10-16-20, 05:13 AM
So, this thing looks like it will splice 2 cables together, which I assume is what would be needed when removing an outlet in the middle of a run. What about when an outlet is at the end of a run and there's only 1 cable in the outlet box? Can you just connect the one end? Also, do these devices get screwed into the studs where the cable would normally be run down a stud inside a wall? Thanks.
Old 10-16-20, 05:58 AM
Norm201's Avatar
Received 230 Votes on 205 Posts
Explain. I don't understand what's not reliable about them. I do understand it's still a concealed splice but how does it make it unreliable and why is this allowed and not a steel box that is totally enclosed?
Old 10-16-20, 06:09 AM
Find the other end of the cable and disconnect it. Then you have no issues leaving a dead cable in the wall.
