Outbuilding power
Outbuilding power
I'm trying to figure out where to pull the power from for an outbuilding. When I built the house 17yrs ago I installed a Square D 200A main breaker panel directly beneath my meter on the pole. I think when I bought the panel this was basically the only type we had locally. I wish it had more lugs so I could feed a couple of outbuildings with power. I'm pretty sure it's not made to put two wires under one lug.
Square D QOM22225NRB
I'm just unsure of how I want to do this. I'd rather not have to get the meter pulled otherwise I would just put in a new panel that has multiple circuits. I've thought about putting another panel directly beneath this one. I need to make sure the wires to the house are still long enough. They go underground to the house. Any ideas would be appreciated.
Welcome to the forums.
You are correct. You cannot double wires up in a single lug.
I'd like to see a picture of everything from further back.
I'd replace that disconnect panel with a new one with several breakers.
A new panel I'm sure is the best way to go.
Yep, a new NEMA 3R 200 amp main breaker panel with feed-thru lugs. Feed the house with the bottom lugs and all other outbuildings from breakers installed in the new panel.
Feed thru lugs would mean the house service is unprotected.
@ Joe...... doesn't the house need to be fed from a breaker ?
Here is the perfect panel for your job: https://www.homedepot.com/p/Square-D...FTRB/204836396 which is what CasualJoe is describing. There is also a Square D QO version of that panel if that is something you are interested in.
Can't you just splice additional wire using a 3 port lug block ( https://www.newark.com/panduit/pcsb4...awg/dp/72K9171 ) or split bolt + tape? I have seen that done in apartments where several units are fed from same main breaker.
Or may be even this tap lug?
https://www.platt.com/platt-electric...spx?zpid=48286
I also have seen wire just tapped using a crimp ring (like the one power companies use) and insulate splice with a plastic wrap over insulator.
If you tapped into the 200A line with bugs..... that would mean you'd have to run 200A wire to the outbuilding. You couldn't tap smaller wire onto 200A cable.
Since the main breaker is 200A, I figured anything feed through has be 200A wire as well.
------------------ EDIT ------------------
I just realized I misunderstood what was getting connected to a feed through lug. Feed through was feed existing line and additional breakers are feeding out building.
I guess adding a secondary 200A sub panel is a option if the electrician finds pulling meter will be a trouble some..
