Loss of power to receptacles
Old 11-19-20, 12:14 PM
C
I was running near 15 amps on a 15 amp outlet. I think I overloaded and burned out the plug. There is no power to any of the outlets in the room.
My questions are do I need to replace the outlet? And if so does it matter which receptacle I buy. Will this ($1.10) Levition work in its place? The outlet that burned out was a "Legrand". Any help is appreciated.
Old 11-19-20, 12:38 PM
P
Received 1,561 Votes on 1,404 Posts
Outlets are pretty standard. I don't know what Leviton you are talking about but even inexpensive ones are generally OK.
cannabool voted this post useful.
Old 11-19-20, 01:06 PM
C
replaced it and everythings working grand! Much thanks!
Old 11-19-20, 01:51 PM
Received 62 Votes on 58 Posts
If you use that cheap $1.10 (Junk) outlet use the screws on the side and not the "QuickWire" (AKA backstab) connections. I buy the better Specification or Industrial grade with the "back-wire" terminals those are the best in my opinion the wire is inserted in the back and tightened against a pressure plate by the side screws.
