Connections from main: help needed
Old 11-19-20, 09:02 PM
K
Received 3 Votes on 3 Posts
Two receptacles in our living room are connected to the chandelier of our living room. So the receptacles do not work unless we turn on the lights.
I have checked that the main from lower level comes to the switch and from switch the wire goes to a junction box. This junction box connects the light as well as the receptacles
My goal is to connect the receptacles directly to the main.
Theoretically, I can cut the main, disconnect the wire from junction to receptacles, connect the two parts of main and the wire to receptacles in a new junction box.
But if I cut the main to switch , there is not enough wire to connect the two pieces of main and wire to receptacles. I am thinking I will probably need to install two junction boxes and use a short wire to extend the main ?
Any other easier solution ?
I am attaching a diagram that will show what is the current connection and what I am trying to do
Popular Reply
11-19-20, 09:47 PM
joed
joed is offline
Received 266 Votes on 230 Posts
The correct term is receptacle. Technically a light is also an outlet in code terms.
Old 11-19-20, 09:08 PM
Change the wire from the switch to the junction to a 3 wire cable. Then you can have a switch and unswitched hot.
cartman voted this post useful.
Old 11-19-20, 09:39 PM
Andrew's Avatar
Received 14 Votes on 10 Posts
What do you mean by "points"?
Thanks,
Andy
Old 11-19-20, 09:44 PM
K
"What do you mean by "points"?
Thanks,
Andy"
Outlet. Sorry -- should have used the correct term
Old 11-19-20, 09:47 PM
AFJES, cartman voted this post useful.
K
I thought that, but accessing the switch is a PITA
Old 11-19-20, 11:34 PM
Then you will need two junction boxes and a short cable to get the proper amount of cable in junction boxes when you cut the main.
Cut the cable install each end into a junction box with the proper amount of cable. Then use a short cable to join the junction boxes.
Old 11-21-20, 01:44 AM
pcboss's Avatar
Received 92 Votes on 79 Posts
If you tell us the number and colors of the wiring in the switch box you might be able to make a change in a splice.
Old 11-21-20, 04:17 AM
Tolyn Ironhand's Avatar
Received 221 Votes on 195 Posts
Also, tell us if you have cable or conduit in the switch box. You might be able to just add a wire.
