Main shut-off in subpanel
Old 11-20-20, 04:16 PM
I
My subpanel did not come with a main breaker or even a main breaker spot. Is there any way to add a main breaker?
Old 11-20-20, 05:30 PM
Received 77 Upvotes on 72 Posts
Depends of the internal layout of the buss bars a panel make & model would be helpful with this.
Sound like you bought a "MLO" (Main Lug Only) panels those are OK as sub panel use only as the protection device is upstream in the main breaker (or fuse) panel.
They are not suitable as service equipment (main panel) and a meter with a main breaker makes the inside panel technically a sub panel.
Old 11-21-20, 01:32 AM
pcboss's Avatar
Received 193 Upvotes on 169 Posts
A main breaker may not be required. Is this panel in the same building as the service?
CasualJoe voted this post useful.
Old 11-24-20, 12:37 PM
CasualJoe's Avatar
Received 183 Upvotes on 165 Posts
Obviously you bought a main lug panel and not a main breaker panel. Most manufacturers sell a main breaker kit that will replace the main lugs so check with the manufacturer to see if a main breaker kit is available. Another option may be to install a backfed breaker as a main breaker along with the required main breaker retaining kit.
Why didn't you just buy a main breaker panel?
