Leviton 5262-IGW Can these be used in "residential" settings?
I scored a lot of 20 Levition 5262-IGW at a surplus dealer for a
steal
of a price of $8 for all 20!
They are almost exactly like the ones above but have white face, the back is blue and they have a green ground wire.
My question is what exactly does "Isolated Ground" and "Mounting Means Not Grounded" mean and can I use these as "normal" receptacles in a standard residential setting with plastic junction boxes?
The stores receipt stated Levition 5320-WCP but I did scan the correct box/ barcode at the self checkout isle.
The 5320-WCP are the cheap POS "Quickwire" things so $8 for 20 of those is a good price but $8 for these is like the price of 1 at most places let alone 20 so I scored a major deal!
This is usually used in lab environment to reduce possible noise from grounding. Separate ground wire is run and grounding for metal conduit is isolated.
You can use for residential setup without problem, but also without any advantage.
This means ground prong of the receptacle is isolated from mounting bracket (where receptacle screws down).
So I would just wire these like normal and attach the green ground to the bare ground from the NM cable with an appropriately sized wire-nut?
These also have the "Green Dot" for Hospital Grade
Doesn't meet NEC because of the requirement to be tamper proof
I don't want to sound rude so please don't take this as such but in my opinion the NEC has gone beyond the "minimum standard" that it is supposed to be and is nothing but a manufactures paradise with kickbacks (probably) from mandating all of this modern junk such as AFCIs on every circuit in the panel and now surge protection in the panel.
I agree with the GFCI technology as they are proven and have been around over 40 years so all of the kinks are pretty much worked out, on the other hand the AFCI technology is fairly new and still has a lot of work to be done before they should be required everywhere.
In setting where isolated ground is wanted a separate green insulated ground wire is run. It is kept separate from the grounding of metal boxes and conduits. The green wire from the receptacle connects to the green isolated ground.
In your home you connect the green wire to all the other grounds in the box or to the screw on a box if the box is metal.
CircuitBreaker voted this post useful.
OK thank you I think my thick head gets the jist of this now.
I was told and looked them up these are Hospital Grade and are the top of the line in the wiring device category as they have to meet vary strict requirements to stand up to the use (and abuse) of a health care facility.
I got a steal on these devices!
MC cable does not use the sheath as a grounding means. You would need 2 identified conductors for isolated ground devices.
If you want to wire them with HCF MC cable, there are 4 wires to work with; 1 hot, 1 neutral, 1 green grd and 1 bonding wire within the metal sheath.
https://www.homedepot.com/p/AFC-Cabl...2-00/204794276
Well the boxes are plastic and most have 14-2 With ground.
Never seen black sheathed NM cable before (this place is from the late 1970's).
I bought them because for $8 why not?
Each receptacle weighs about 1 LB or more way heaver the 5320 ones.
Only four 20A circuits in the whole place Living room Kitchen x 2 electric base board heat (240V double pole so six 20A breakers but four circuits)
The devices are 15 amp rated so 14-2 will work. They will also work on 20 amp circuits. I recall some black NM cable from the late '70s, it was Southwire as I recall. Back in those days I would avoid Southwire products because their NM cable was so stiff and hard to work with, but it was priced right. I also recall brown and red NM cable in addition to white. My favorites back then were either General Cable or EtcoFlex which was very flexible and easy to work with, both were white.
