Two wire thermostat on 4 wire electric baseboard heating
Received 0 Votes
Hi, I am trying to replace my old mechanical thermostat for my electric baseboard heating so that I can have better control over the set temperature. I remove the old thermostat and disconnected the wires and there were 4 wires coming from the wall-two white and two black. The thermostat I bought is a Honeywell rlv3120 which only has two wires coming out the back. Can I wire this thermostat up to my current wires and if so how would I do it? If I can't, then do I need to buy a different thermostat or do I just have to stick with my old mechanical thermostat? Thank you for your help!
Provided you meet the following condition, it can be used.
The RLV3120 thermostat CANNOT be used with a resistive load under 0.83, a resistive load over 8.3 a system driven by a contactor or a relay (inductive load), a fan-forced heating system (e.g. : fan-forced convector) or a central heating system.
You connect the white wires together and connect the thermostat to the two black wires.
Yes....you would see a spark.
You should have the breaker off before making any wire changes.
That thermostat is limited to a maximum of 8.3amps @ 240v which is 2000 watts of heater.
Received 0 Votes
I had the breaker off when I was making the wire changes but after I turned it on was when I saw the spark. I guess I will probably need a higher rated them thermostat. Any recommendations on thermostats?
You picked a digital thermostat.... is that what you want ?
Have you calculated how much wattage you have in heat strips ?
Just add the linear footage and let us know.
The Honeywell line pro stat is good for 3600 watts.
Received 0 Votes
I have two separate baseboard heaters. Wasn't able to measure their exact length as I am not home but that is about what I estimate them to be. On a side note, are in wall heats like from cadet more efficient than electric baseboard?
Electric baseboards are slow acting heaters. Once they get warm they offer continuous heat.
A wall heater with a fan may heat the room quicker.
There is no loss with either type of heater so neither one is more efficient.... just maybe faster acting.
