Outlet problem
Outlet problem
Hello looking for some advice.I have an outlet that is a light switch 2 outlets in one.I plugged a nightlight into the outlet and it sparked and blew breaker.I tested the voltage and i am gettin around 120 from neutral to hot,and nothing from ground to hot.What could have happened,it worked fine before.Thanks.
Welcome to the forums.
I think you have that wrong.... 120v from neutral to hot is correct.
Nothing from ground to hot could mean an open ground,
