3 way switch troubles
Old 06-18-01, 08:41 PM
Anyone ever had this trouble with a 3 way circuit? I have one 3-way circuit controlling a light on a ceiling fan. When you turn off the light from one switch, you can only turn it back on at the same switch. The light can be turned
off from either one. I've checked all the wiring I know about. Please help!!
Old 06-18-01, 09:00 PM
RickM
This is usually an indication that either the switch was mis-wired (did you recently change either or both of the switches?) or a faulty switch.
To verify the wiring, check out http://www.danswiringpage.com
He has alot of diagrams on wiring three ways.
Good luck.
Rick Miell
